N983LK
Date:  3-15-2022
Number of Hours:  0.50
Brief Description:  Rudder wedge
Attached a 3-D printed wedge ( from rvplasticparts.com ) to the lower left hand trailing edge of the rudder using 3-M foam tape. The rudder is about 1/2 ball out to the right at cruise speed. The wedge will deflect the rudder to the right and hopefully center the ball. If it works I may keep it or replace it with a similar sized aluminum trim tab.
