Replaced the 2 inch throttle lever on the fuel servo with one that is 1.632 inches to increase the rotational travel of the throttle in order to reduce the idle RPM of the engine. Reinstalled the throttle linkage and adjusted it so that the servo hits the stops before the throttle cable hits the limit of its travel.
Installed one of the Reiff heated cylinder bands on the base of cylinder number 1.
