Reconfigured the Skyview engine bottom band to correct the positions of the Left and Right fuel tanks. The left is now on the left side and the right is on the right side
Replaced the tail wheel bolt with one from Flyboy's that is meant for use with a tow bar. It has a lug on each side in place of the bolt head and nut that fit inside the recepticles on the tow bar and prevent the towbar from slipping off.
