Removed the cowl and forward baggage shelf. Tighted the fuel lines between the LH gear tower and the fire wall. Fabricated an aluminum tube to connect to the engine side of the firewall fuel fitting for use in testing the boost pump.
Removed the wheel pants and upper instersection fairings.
