N983LK
RV-8
Upper intersection fairings continued
Removed the RH upper intersection fairing and trimmed and sanded the plies that were laid up yesterday
Installed a nut plate in the side of the fuselage to hold the upper flange of the RH fairing.
Reinstalled the RH fairing and laid up two plies to fill in the area around the forward outboard landing gear bolt.
Sanded the epoxy/ flox on the aft edge of the RH wing tip. Laid up some more epoxy/flox on the inner inboard edge of the trailing edge.
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
