N983LK
RV-8
More misc tasks
Applied three stips of 2 inch wide anti-slilp tape to the top of the left wing walk area.
Configured the VP-X pro to have the alternator field wire turn on with the Alt switch and the voltage regulator sense turn on with the battery switch
Applied the registration numbers to the sides of the aft fuselage
Began trimming the RH upper intersection fairing for clearance from the landing gear outboard attach bolts/nuts.
Anti-slip strips on LH wing
Registration nunmber
Trimming the RH upper intersection fairing to fit
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
