Removed the clamps from the RH wing tip trailing edge and sanded the cured epoxy/flox. Applied epoxy/micro to low spots near the inboard edge of the trailing edge.
Installed the rear seat harness using -6 bolts rather than the -5s called out on the plans (which were too short due to the thicker lugs on the hooker harness) . Torqued the bolts and installed cotter pins.
