N983LK
RV-8
RH wing tip aft end re-bonding
Removed clamps from LH wing tip and sanded the cured flox/epoxy.
Installed the RH wing tip. Applied epoxy/flox inside the open aft end of the wing tip. Clamped the level to the aft end of the wing tip and alieron.
LH wing tip
RH wing tip
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
