N983LK
RV-8
Various tasks
Tightened the brake lines at the parking brake valve
Trimmed the aft fuselage cover plates to clear the elevator horns. Installed the plates on the fuselage.
Installed the wing access plates
Tighted the fuel lines on the bottom of the fuel selector valves. Installed the fuel filter.
Put together a fluid pump system using a garden sprayer and various sizes of clear tubing. The pump will be used to fill the brake system.
Elevator horn fastener inspection window
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
