Updated the airspeed limitations in the Skyview system.
Installed the ELT
Replaced the forward row of baggage floor screws with black ones
Installed the tail wheel link. I had to cut 1/4" off one end to make it fit.
Adjusted the rudder cables by moving 6 washers from the front of the firewall to aft of the firewall. This effectively lengthened the cables and allowed the rudder to move through it's full range of motion.
Installed the rear seat shoulder harnesses and the RH rear seat lap belt. Used the scotchbrite wheel in the bench grinder to reduce the width of the bushing in the lugs so that they were just proud of the edges of the lugs. This was necessary so that the bushings fit in the gap in the lugs riveted in the fuselage. I'll also need to order longer bolts since the bushings are still wider than what the fuselage lugs were designed for.
