Brief Description: Rear baggage floor and Autopilot calibration
Wrapped some roundit sleeving around the ADS-B In antenna coax where it goes through a lightning hole in the baggage floor frame. This was done as a precaution to prevent chafing of the coax if it comes in contact with the frame (I also have race track on the inside of the hole).
Installed the rear baggage floor and screws.
Checked the torque on the bolts and lock nuts on the flight control linkages at the elevator bellcrank. Applied torque stripes.
Ran the autopilot servo setup/configuration procedure in Skyview and tested the autopilot operation. Tested OK.
