Installed adle clamps to secure the RH fuel feed line to the front of the spar
Scuffed cleaned and primed the area of the fuselage skins that will be under the LH and RH flap fairings.
Cut the wing root end of the VOR/ILS antenna coax to length and installed a BNC connector on the end. Attached the BNC to the male BNC mounted to the fuselage side under the wing root fairings
Riveted the forward section of the flap fairings to the fuselage. I’ll need help bucking the rest but with the forward section riveted I can now reinstall the aft cabin floors.
Installed the aft cabin floors and screwed them in place
Reinstalled the flap weldment
Installed the LH and RH bulkhead caps and blind riveted them in place
Installed a sticker on the lower switch panel that shows the functions of each of the buttons on the pilot's stick
