N983LK
Date:  9-16-2021
Number of Hours:  3.00
Brief Description:  Roll servo wiring and fuel sensor wiring
Cut the inboard end of the roll servo wire harness to length and terminated the wires with D-sub sockets. Installed the sockets in a CPC connector/backshell and connected it to the other half of the connector that was previously installed in the fuselage.
Cut and terminated the fuel servo wires with ring terminals and connected them to the sending units on the LH and RH fuel tanks.
Painted the heads of a bunch of #8 screws that will be used for installation of floor panels and interior panels. Baked the screws
Bonded a click stud to the fuselage floor to replace one that I knocked off while installing the wing attach bolts.
Roll servo wire CPC connector
Fuel quantity wire connected to the fuel level sending unit
Interior screws painted
