Brief Description: Pitot heat and stall warning wiring
Cut the pitot heat and stall warning wires from the wing to length and terminated them with CPC pins. Installed them in a CPC connector which was then connected to the CPC socket connector previously installed in the fuselage.
Cut the pitot and AOA tubes and connected them to the tee and elbow connectors in the fuselage.
Installed the pitot tube and hooked up the wiring and pitot/AOA tubing
Configured the pitot heat sensor in the Skyview system.
Tested the Pitot heat. It got hot quickly and shut off when it reached temperature.
