Removed the clamps that held the tailing edges of the wing tips together while the epoxy/flox cured. The trailing edges are now deformed a bit and not parallel to the ailerons when viewed from behind. I'll have to cut them apart and try again, this time with them clamped to a straight edge.
Removed the wingtips, ailerons, flaps and aileron pushrods. Removed the aft spar attachment bolt.
With the help of my Son and Son in law removed the wings and placed them on stands with the root ends a couple of feet from the fuselage. This will give me room to finish up the tasks on the root end.
