Brief Description: Flap fairings and wing tip trimming
Formed the flap fairings to fit the fuselage. Taped them in place and match drilled them. Clecoed the fairings in place.
Installed the wing tips which took longer than I expected. I had to clean some adhesive out of the hinges that hold them on, trim an inch off of the tip of the upper hinge pins and sand the inboard edges of the wing tips to make them fit a little better. All of this was required in order to get the hinge pins all the way in.
Trimmed the aft edges of the wing tips even with the ailerons. Split the wing tips apart at the aft end so that I can apply some epoxy/flox to reinforce it where it was trimmed.
