Brief Description: Aileron and flap installation and adjustment
Installed the ailerons and pushrods. Adjusted the pushrods so that the ailerons are in the neutral position when the control stick is vertical.
Measured the up and down throws of the LH and RH ailerons. Both were within spec.
Installed the flaps. Trimmed the inboard edges of the upper flap skins to eliminate contact between the flaps and fuselage skins. Installed the flap actuator weldment and connected the flap pushrods to the flaps and flap actuator weldment. Trimmed the flap pushrod openings in the fuselage skins to eliminate interference. Adjusted the flap pushrods so that the flaps are lined up with the ailerons in the neutral postion when they're fully retracted.
Tested the operation of the flap motor and flaps using the flap switch on the control stick and the VPX controls on the PFD. The flap operation was reversed from what it should be so I reconfigured the VPX to reverse/correct the flap motion.
