N983LK
Date:  8-11-2021
Number of Hours:  2.50
Brief Description:  Hooked up tail nav/strobe
Terminated the ends of the tail light wire and the tail nav/strobe pigtail with seal-all connectors and inserted them into the backshells. When I attempted to fish the wire/connector combo through the rudder bottom I found that the aft end of the rudder bottom is too narrow for the connector backshells so I cut the seal-all connectors off and went with plan B which was to use D-sub pins and sockets covered by shrink tubing.
Installed and tested the nav/strobe. both the nav and strobe work but I found that if I turn off the nav with the strobe still on the strobe will flicker at low intensity. If I turn the strobe off and back on it works normally. I'm hoping it won't do it once the wing nav/strobes are hooked up. Otherwise I'll need to do some troubleshooting.
D-subs covered with shrink tubing
Tail nav/strobe installed
It works!
It works!
