Sanded the elevator tips and primed with filler primer. When that dried I wet sanded it and sprayed with sandable primer
Installed the vertical stabilizer on the fusealge. Torqued and torque striped the nuts.
Installed the data plate on the fuselage
Fabricated and installed a new elevator trim tab hinge pin that has a dog leg at the inboard end to allow it to be secured to the elevator. Drilled a hole through the elevator aft spar and inboard rib and secured the hinge pin to the elevator with safety wire.
