N983LK
RV-8
More empenage work and misc
Sanded the micro on the bottom of the tip caps on the horizontal stabilizer. Applied superfill to the pin holes.
Removed the vertical stabilizer so I can take it home and lay up some plies over the tip cap close out.
Filed the canopy latch to reduce the force it takes to close it
Removed the cowl and replaced one of the spade connectors on the #4 CHT wire that had been installed incorrectly and was causing intermittent readings
Sanded the superfill on the HS tips. Applied spot putty
Spot putty on the horizontal stab tip cap
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
