Removed the tape and plastic wrap from the canopy bubble and cleaned the surface with mineral spirts and soapy water.
Installed the cowling, Took the tail wheel off of the saw horse and placed it on the ground. Moved the fuselage over so it lines up with the far garage door in preparation for moving it to the hangar.
Applied three coats of neat epoxy pin hole filler to the areas of the wheel fairings and lower intersection fairings that had newly laid up fiberglass or micro instead of gel coat
