Sanded the micro on the RH wheel fairing assemblies
Installed three blind rivets in each LH lower intersection fairing through the wheel fairing halves. Sanded the edges of the intersection fairings and applied epoxy/micro along the edges of the intersection fairings and on to the wheel fairings.
Sanded the high build primer on the canopy skirt. Applied a coat of sandable primer.
Sanded the lower cowl half at the outboard edge of the inlet and applied epoxy/micro to build up the surface to match the upper cowl half.
