N983LK
Date:  7-13-2021
Number of Hours:  4.00
Brief Description:  Wheel fairings part 19
Trimmed the fiberglass extension on the aft half of the LH lower intersection fairing to match the forward half.
Prepped the surfaces of the LH wheel fairing and LH lower intersection fairing halves, applied T-88 structural adhesive and clecoed them in place.
Removed the RH wheel fairing assembly (with lower intersection fairings bonded in place). Installed three blind rivets in each intersection fairing through the wheel fairing. Sanded the edges of the intersection fairings to reduce the steps at their edges and blend them to the surfaces of the wheel fairings. Mixed up some epoxy/micro and applied it along the edges of the intersection fairings and on to the wheel fairings.
Wet sanded the canopy skirt and applied some more primer where needed.
Removed the pilot's seat and pilot's floor.
LH lower intersection fairings being bonded to the wheel fairing
Epoxy/micro curing on RH wheel fairing assembly
