Bonded the RH lower intersection fairing halves to the wheel fairing with T-88 structural adhesive.
Removed the canopy and placed it on the canopy stand. Sanded the canopy skirt and forward reinforcement strip.
Applied spot putty to the aft end of the canopy skirt. Wet sanded it after it dried.
Sprayed high build primer on the canopy skirt, forward reinforcement strip and parts of the cowl halves. Wet sanded the primer after it dried. Applied additional primer in some areas.
Bonding the lower intersection fairing to the wheel fairing
