Removed the aft half of the LH lower intersection fairing and cleaned up the freshly cured epoxy/flox.
Decided to extend the edge of the inboard vertical seam on the aft fairing to close up the gap between it and the forward half. Sanded a scarf on the edge, clecoed the fairing half in place, build up the area with modeling clay and laid up 5 plies of fiberglass/epoxy to extend the edge.
Applied spot putty pinhole filler to the canopy forward reinforcement strip. Wet sanded it after it dried.
Epoxy/flox edge extention on LH lower intersection fairing aft half
