N983LK
RV-8
Wheel fairings part 12
Completed the wheel fairing alignment jig using the installed RH fairing as a baseline.
Installed the jig on the installed LH fairing and verified that the LH fairing was shifted 1/4 forward from the position of the RH one.
Drilled out the four 1/8-inch rivets holding the bracket to the U-808 LH aft wheel fairing half.
Mixed up some flox/epoxy and filled the mounting holes in the LH wheel fairing halves.
Wheel fairing alignment jig
Filling the mounting holes in the LH wheel fairing halves
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
