Wet sanded the primer on the oil door and upper cowl
Riveted the oil door hinge halves to the door and upper cowl.
Applied spot putty to areas on the cowl where fiberglass, flox or micro was used to build up the cowl surfaces. Wet sanded the spot putty after it dried. Sprayed sandable primer.
Started fabricating a wheel fairing alignment jig to use in comparing the alignment of the left wheel fairing to the right one to help determine why the fairing splitlines are off between the left side and right side.
