N983LK
Date:  6-22-2021
Number of Hours:  4.00
Brief Description:  Cowl part 38
Fabricated an oil door latch striker plate. I cut a section from the solid portion of a stainless-steel hose clamp and riveted it to a piece of fiberglass left over from trimming excess off of the cowl. I then cut a notch in the oil door flange in the upper cowl that would allow the striker plate to sit nearly flush in the opening. I then bonded the fiberglass strip to the inside of the upper cowl and also installed some blind rivets in the two parts.
Rounded the corners of the oil door to a 1/2 inch radius. Wrapped the edges of the oil door with 3 layers of electrical tape. Sanded the oil door flange on the upper cowl and applied epoxy/micro to it. Installed the oil door on top of the micro and latched the door in place. Smoothed out the micro around the periphery of the door.
Oil door striker plate
Striker plate installed
Molding oil door opening to match door
