N983LK
Date:  6-19-2021
Number of Hours:  4.00
Brief Description:  Cowl part 36
Installed the alternator and torqued the mounting nuts and bolts. Installed safety wire in the belt tension arm bolts. Checked belt tension.
Cut Friberfrax heat blanket strips to shape and bonded them to the lower cowl with Pliobond. These strips will be covered with sheets of Themo-tec aluminized heat barrier.
Alternator installed
Cutting Fiberfrax strips
Fiberfrax strips in place
