Brief Description: Lower intersection fairings part 3
Continued fitting the RH lower intersection fairing. Cut off the upper forward corners of the inboard and outboard flanges of the fairing because there was a gap between it and the landing gear leg. Sanded a scarf on the interection fairing and replaced the fairing on the LG leg/wheel pant. Used modeling clay to build up the area where the intersection fairing was cut and formed it into a taper down to the LG leg. Layed up 5 fiberglass plies over the scarf, clay and LG leg.
