N983LK
Date:  5-30-2021
Number of Hours:  6.00
Brief Description:  Baffles part 42
Removed baffles from engine. Sealed seams and openings with loctite 598 RTV. Sealed gaps in the intercylinder baffles on the engine.
Trimmed and sanded the epoxy/flox extension that was built up on the aft end of the RH side of the upper cowl yesterday.
Drilled 1 inch holes in the aft wheel fairing halves to allow access to the valve stems without removing the wheel pants. Drilled rivet holes to mount spring loaded doors that will close off the 1" holes.
Sealing openings baffles with RTV
Valve stem door
Valve stem door
