Sprayed the snorkel with Duplicolor white engine paint but the paint clumped badly even after heating the can and shaking it for an extended period. I'll have to sand the clumps out and spray with a different brand of paint.
Trimmed a little more material off of the cylinder #3 baffle
Fabricated a steel clip to mount an adel clamp on the bottom of the #4 cylinder baffle for supporting the alternate air door cable and some wires.
Sprayed the baffles on the RH side with engine primer after scuffing and cleaning.
