Cut foam to fit under the aft/inboard edges of the upper cowl inlets and applied a layer of micro on top of it. The foam will be used as a mold to layup fiberglass plies to form a radius at the edge of the inlet to create a smoother transition from the inlet to the cowl surface to facilitate better sealing of the baffle.
