N983LK
RV-8
Baffles part 28
Began trimming the forward baffles.
Applied epoxy/flox to the edges of the upper cowl inlets to smooth the transition to the upper cowl inner surface.
Sanded some high spots on the snorkel and filled some low spots with poly-fiber superfill
Trial fit of forward baffles between cuts
Flox on inlet transitions
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
