Trimmed the opening in the RH inlet ramp some more.
Settled on the final position of the snorkel, clamped it in place and marked the location for the lower right 1/4-20 fuel servo screw. Removed the snorkel and drilled the hole.
Removed the centering tool from the fuel servo and bolted the snorkel in place using the 1/4 hole I just drilled. Verified positioning/fit. Removed the snorkel and used the centering tool as a drill template to mark the location of the remaining holes. Drilled the holes.
Reinstalled the snorkel and marked the outline of the fuel servo on the snorkel flange. Removed the snorkel and trimmed the snorkel flanges. Bolted the snorkel back in place.
