Trail fit the engine intake snorkel on the engine. Used the alignment tool I had previously fabricated and installed on the front of the fuel servo to center the snorkel outlet on the fuel servo. Rotated the snorkel around the servo until the inlet end contacted the RH inlet ramp. Marked the outline of the snorkel on the inlet ramp and cut the ramp on the marked lines. Reinstalled the ramp and checked snorkel fit. Made a few more small cuts. The opening will eventually be 3/8" wider than the snorkel on all sides so these initial cuts don't have to be precise.
