Continued working on the RH inlet baffle and #2 cylinder baffle which required more iterations of installing/removing the cowl and baffles and trimming and bending the baffles. Got them to fit well.
Cut and bent the bottom of the cylinder #2 baffle 90 degrees to support the RH inlet baffle/ramp
Laying out the support tab on the cylinder #2 bafffle
Bending the support tab on the #2 baffle
RH inlet baffle and #2 cylinder baffles trimmed to size
