Countersank the rivet holes for in the lower cowl for the RH row of Skybolt Flanges.
Drilled #12 holes in the Skybolt flanges for the "Flox Rivets"
Fabricated a filler flange to be riveted to the lower cowl aft of the row of Skybolt flanges to cover the gap between the two cowl halves. Match drilled the filler tab and lower cowl.
Riveted the RH row of Skybolts to the lower cowl with epoxy/flox in the #12 holes.
