Installed both cowl halves on the fuselage and marked a line on the fiberglass splice on the lower cowl corresponding with edge of the upper cowl. Removed the upper cowl and trimmed the lower cowl just above the line. Sanded to the line.
Drilled rivet holes for the remainder of the RH Skybolts except for the forward most one.
