N983LK
Date:  3-13-2021
Brief Description:  Fuel flow sensor wiring part 2
Installed a replacement fuel outlet packing (O-ring) in the fuel servo. The previous one was damaged when I swapped the fuel outlet fitting from the primary location to the alternate location.
Covered the fuel flow senor D-sub pins with shrink tubing. Reinstalled the fuel flow sensor.
Reinstalled the fuel servo on the engine. Torqued the nuts to 200 in-lbs and applied torque paint.
D-sub pins for fuel flow sensor wires
Fuel flow wiring completed
Fuel servo nuts
Fuel servo nuts
