Mounted the upper cowl to the fuselage. Used a laser level lined up with the center of the spinner to define the bottom edge of the upper cowl. Marked the cut line on the cowl.
Removed the upper cowl and trimmed it close to the line. Began sanding the edges with long sanding boards and 80 grit
