N983LK
Date:  2-19-2021
Number of Hours:  5.00
Brief Description:  Cowl part 3
Removed the wheel pants and leveled the fuselage.
Set the top cowl half in place with a 1/4 inch shim between it and the spinner. Marked the aft end of the cowl for the cutline. Removed the cowl and used a dremel cutoff tool to cut close to the line. Used a long sanding board to sand to the line.
Fit the cowl in place and marked where additional material needed to be removed. Repeated 4 or 5 times for fit
Setting 1/4 inch gap
Sanding down the aft end
Fitting the aft end
Fitting the aft end
