N983LK
Date:  2-11-2021
Number of Hours:  1.50
Brief Description:  Baffles part 7
Drilled a 1 inch hole in the RH inlet baffle and support angle for clearance of the propellor oil line.
Deburred the components for the inlet baffles.
Riveted the air damns on the inlet baffle support angles.
Attached the inlet baffles to the engine.
RH inlet baffle
RH inlet baffle
Hole for prop oil line
LH inlet baffle
LH inlet baffle
