Brief Description: Wheel alignment adjustment again
Removed the wheels, brakes and axels.
Checked the wheel alignment using the 48 inch angles clamped to the gear legs with a .5 degree shim between the angle and leg (thin part aft) and a .75 degree shim on the RH side (thin part aft). With this configuration both wheels have a .15 degree toe out.
