N983LK
Date:  8-27-2020
Number of Hours:  3.00
Brief Description:  Baggage door lock arm
Fabricated a replacement lock arm with the square drive hole in the center rotated 45 degrees. Using this in lieu of the one sent from Van's will align the lock pins with the key slot in the lock.
Attached the lock pins to the lock arm, installed the clevis pins and secured them with safety wire.
Scuffed, cleaned and primed the inside of the baggage door inner skin.
New lock arm (bottom)
Lock pins on lock arm
