Realized that I mixed the epoxy at the wrong ratio yesterday when I laid up the plies on the aft IML of the canopy skirt. The resin was still somewhat soft so I peeled the layup off and redid it.
Countersank the holes in the windscreen and screwed it in place to the windscreen support.
Laid out the lines on the forward top skin that will mark the windscreen boundary
Received the 3/16" x 1" detent pin that I ordered from amazon and test fit it in the receptacle for the rear stick. It fits perfectly and does not come out unless the detent release button is pressed. As a safety precaution, I secured the split ring on the pin to the receptacle with a strip of Velcro. This pin will make it possible to remove/install the rear stick without tools.
