Match drilled the holes from the forward skin support ribs into the windscreen support. Removed chips, deburred and installed the blind rivets
Temporarily located the windscreen in place on the fuselage and marked the outline where it contacts the forward top skin. Masked off the edge with 1/4 inch trim tape. Wet sanded the primer with 1500 grit and sprayed the glare shield area with Rustoleum truck bed paint.
Once the truck bed paint was dry I installed the avionics fan and grill.
