Wet sanded the spot putty on the IML of the canopy skirt and sprayed it with high build primer.
Routed the front cabin air vent hose for the RH vent, secured it with stick on tabs and zip ties and connected the hose to the vent.
Masked off the front seat lap belt supports and sprayed with interior paint.
Received the brake hoses and fuel hoses I ordered from TS Flightlines. The brake lines are to connect the bottom of the landing gear to the brake caliper and the brake master cylinders to the bulkhead fittings. The fuel lines were to replace ones that I had made from soft aluminum tubing per the plans and just wasn't happy with .
Attached the brake lines to the brake master cylinders.
Removed the front seat support and front and rear pilot sticks
