N983LK
RV-8
Landing gear brackets etc
Modified and installed the gear bolt retaining clips for the LH side.
Installed the remaining landing gear brackets and wear plates.
Checked the torque of the brake fittings in the RH gear tower.
Drilled a 5/8 inch hole in the firewall and installed a fireproof fitting. Installed the push-pull cable for the alternate air door.
Installed the hoses for the front cabin air vents and worked out routing
Alt air door passthrough
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
