Sanded the neat epoxy on the wing tips and sprayed the exposed areas with high build primer. I'm not sold on using neat epoxy for pin hole filling. You're not supposed to sand through it but in order to get all of the high spots off and yield a uniform surface I end up cutting through to the micro. The epoxy also drips and runs which leaves ridges that need to be sanded off. I think I'll use spot putty from now on.
Applied some touch up to the primer on the landing gear legs.
